Code reader
Code reader
Postby MJ310 » Fri Apr 21, 2017 10:29 am
What are people using to access the error codes, is there something I can download to PC?
MJ310
Re: Code reader
Postby silver MZ-1000s » Sat Apr 22, 2017 8:59 pm
MJ , the plug for the scanner is located under the driver seat , i was lucky to get the original MZ scanner when i both my silver 1000s , its a regular OBD 2 plug , idk if any car OBD scanner will read the codes i never try , i will take the pics next week and posted here . Also i will try a car scanner and see if it will show anything when pluged in .
silver MZ-1000s
Re: Code reader
Postby MJ310 » Sun Apr 23, 2017 2:45 am
Thanks, I have a plug and use it on my other bikes but I don't know what software to use.
MJ310
Re: Code reader
Postby Thorsten-aus-SO » Fri May 05, 2017 1:07 pm
Btw.
A number of original MZ scanner (FR2000) are just offered at www.muz.de.
Thorsten-aus-SO
Re: Code reader
Postby MJ310 » Sun May 07, 2017 2:23 am
Thanks for that but £500 is far too much to spend on a single bike scanner.
MJ310
Re: Code reader
Postby boilermaker » Sun Aug 06, 2017 5:49 am
Any cheap fault code scanner will read your codes. Mine is a cheap one @ £25 from e-bay and it reads all codes. It also comes with a code book as the codes are general. When I find the bloody handbook I will give you a name.
boilermaker
Return to 1000S
Users browsing this forum: No registered users and 111 guests
