Remus slip on / neutral light?
More questions, and hopefully no one is sick of me asking so often.... but again, just coming up to speed on this bike.
When the bike is cold, I have no neutral light (42 degree F), above this, when off the neutral light is fine.... once started the neutral light will come on, but it flashes, and not with any predictable sequence, just flashes on and off, sometimes fast, sometimes slower. Turn off the bike.. light is solid. Always goes into neutral and unlike my Ducati that had a neutral light issue, it does not shut down the bike... the Duc had a dirty lockout switch ground issue, and it would go into neutral, but shut off the min you released the clutch in neutral... I was wondering if this could be a similar issue, just a dirty connection or something else.
I also have a set of Remus Revolution slip on's on the bike... nice sound, but a bit quiet compared to my Duc or T-Bird Sport... but the pipes do have removable baffles.... does anyone out there run a set of these pipes without the baffles? What do you think of them without baffles? Better in or out?
Is there any gains other than noise, and does anything need to be changed for mapping to not loose power?
Before I start experimenting, I thought it best to ask.... again new to the bike and I might be missing something through ignorance. The Yamaha VMax for example, if you slap on a slip on, which removes the rear cross over... you get a lot of noise, but actually loose power overall ... a full system and you get more noise but also get more power, which is a worthwhile trade.
If i could get it to breath a bit easier without the baffles, and let a bit of the roar out as well.... all while getting a bit more power... that would be ideal. If I'm sacrificing some power for just noise, it's not worth it.
All input/thoughts/recomendations appreciated!!
Thank you!!
Scott
Albany NY USA
Thank you!!
Scott
Albany NY USA
