Gear selector
Posted:
Sat Nov 15, 2014 11:43 am
by MJ310
Having just given my bike a service it seems to run stronger and smoother at low revs but I have noticed it's very difficult to block change down, I have to change down one gear at a time and release the clutch between gears or it wont shift, had to pull away in second a couple of times. Checking the lever it seems fine and returns to a central position easily. Has anyone any idea what it might be? I have blead the clutch and will do it again tomorrow just in case I have a bit of air in the system.
Re: Gear selector
Posted:
Sat Nov 15, 2014 3:51 pm
by DAVID THOMPSON
sounds like your not getting a full stroke on the lever air in line maybe
Re: Gear selector
Posted:
Sun Nov 16, 2014 5:26 pm
by MJ310
Today I stripped, cleaned, greased and refitted the gear lever and rose joints. I also reblead the clutch, (no air) so I will test it out when I have time.
Re: Gear selector
Posted:
Sun Nov 30, 2014 9:47 am
by MJ310
Took the bike out for a spin yesterday and the gear lever is fine, I still think the spring is a bit weak but it changes gear properly now, did'nt think it was that gummed up but it does'nt take much.
