'96 Skorpion - No Spark, How to test the coil, CDI etc?
Postby pwillikers » Thu Feb 14, 2008 2:59 pm
My Skorp won't start. It cranks fine but there's no spark at the spark plug. I probed around and found 12V on the RW (red/white) wire between the coil and the ignition module in the attached photo. I replaced the spark plug and still no spark. I believe the only remaining suspects are the ignition coil, the ignition module and the "trigger coil in engine". What's the procedure for checking these? What voltage, resistance should I see where and when? Thanks.
Skorpion Ignition & Start.jpg (146.04 KiB) Viewed 2604 times
Paul
'96 MZ Skorpion Sport - track bike extraordinaire
'99 BMW R1100S
'00 Suzuki SV650
'09 Buell 1125cr
pwillikers
Re: '96 Skorpion - No Spark, How to test the coil, CDI etc?
Postby DAVID THOMPSON » Fri Feb 15, 2008 1:06 am
in the middle of picture cut off relay also labeled relay 19 on my rt125
it died on my rt125 but before it did made the tach. read funny
do a search on site for relay 19
ar dave
jumper red black to red white at relay pin 3 to pin5
if bike starts and runs relay is not passing enough current to power everything
the relay on mine was very small and supplies power to a lot of the bike
link to my past post on relay 19
viewtopic.php?f=4&t=2085
Postby pwillikers » Sat Feb 23, 2008 6:54 pm
Just to close the loop on this topic. After an hour or so of probing with a meter etc. it miraculously fixed itself and now sparks nice and fat.
Paul
'99 BMW R1100S
'00 Suzuki SV650
'09 Buell 1125cr
pwillikers
Postby DAVID THOMPSON » Sun Feb 24, 2008 12:07 am
these bikes go bad on the plugs in the wiring harness the inside of the plug turns green
and in the rt125 i had a break in a wire.. when i found it the outside cover of wire was ok
inside was full of about 10mm of green slime that used to be the 14 gage wire
i under stand electrical and it a is a pain to find some times
i have been complaining for years about the too complex wiring harness on bikes
and it just gets worse just wait a while
they will be painting the tail lamps and turn signals on the body panels
with a digital module on the back side that will make it work with a signal
from the ECU
boo
ar dave
Users browsing this forum: Bing [Bot] and 7 guests
