replacement voltage reg rec
Postby DAVID THOMPSON » Wed Mar 01, 2006 1:00 pm
replacement voltage regulator for 125cc
cut wires from old oem unit and use to make cable to hook
this one up
switched 12volts required for sence wire not on oem unit
they will ship direct and retail to end user
may work on other mz bikes
https://www.electrosport.com
https://www.electrosport.com/Images/fitting.esr600.pdf
reg rec
Re: replacement voltage reg rec
Postby Igor » Sat Apr 19, 2008 3:30 am
Can you tell me where regulator is located? What should I take off and unscrew to get to the regulator?
Igor
Postby DAVID THOMPSON » Sat Apr 19, 2008 11:36 am
it is mounted on the bottom of air filter box on mine
Users browsing this forum: No registered users and 54 guests
