Left hand crankcase cover removal.
Postby millhouse mark » Wed Jul 09, 2014 7:38 am
I want to remove the left hand crankcase cover as it appears when the oil levels are correct I have a leak on the joint chucking oil over the back end. Removed all screws, kickstart & gear lever, clutch cable but the case will only come out about 6mm then sticks. I am reluctant to use force; am I missing the obvious?
Regards
Mark
millhouse mark
Re: Left hand crankcase cover removal.
Postby DAVID THOMPSON » Wed Jul 09, 2014 9:11 am
which model bike
Postby arry_b » Wed Jul 09, 2014 4:28 pm
I'm guessing it's a 250/300 of some type going by your description of where the parts are located.
If so, put the kickstart back on now before you take the cover off.
You need to remove the bolt from the end of the crankshaft, under the circular clutch cover which is held on with three screws.
You'll need something to lock the engine (a rope down the plug hole) and a 22mm deep socket to get the nut off. The cover then pulls off easily.
arry_b
Postby millhouse mark » Thu Jul 10, 2014 1:17 pm
Sorted chaps; thanks for your help anyway; just waiting for new gasket set now.
millhouse mark
Users browsing this forum: Google [Bot] and 14 guests
