TS 150 Idling speed
TS 150 Idling speed
Postby JawasandMZs » Thu Feb 18, 2021 8:02 am
Firstly, is it just me? I can't upload pics on this site. Grr.
My new150 won't idle. There's only adjustment screw, on the left hand of the carb. It isn't right under the throttle slide, but further back. Nor does it go in at an upward angle. Turning this screw has no effect on the idling speed.
There is no other screw on the carb.
The bike goes great btw. Obviously it's not powerful enough to be useful for anything other than mooching about on but I have bigger bikes for actually going somewhere. (And a car) And the mix IS 33:1
JawasandMZs
Re: TS 150 Idling speed
Postby Puffs » Thu Feb 18, 2021 8:26 am
Postby Kruh » Thu Feb 18, 2021 12:28 pm
The screw colser to the filter adjust the idle mixture (amount of air).
A quick look at some pics, clearly shows the idle screw. Perhaps, the screw is missing, the head is damaged or its just plugged up.
Kruh
Postby JawasandMZs » Thu Feb 18, 2021 1:56 pm
Oh everyone, have found how to adjust tickover. Turn the screw at the top of the carb anticlockwise so the needle sits higher in the carb. Easy as that!!
JawasandMZs
Postby Blurredman » Fri Feb 19, 2021 4:33 am
I was going to say:
Maybe the previous owner made the bike 'not idle' because of one of those stupid old myth that still gets about 'these bikes were not made to idle'.
8)
Postby Puffs » Fri Feb 19, 2021 5:38 am
Postby Blurredman » Fri Feb 19, 2021 6:31 am
Puffs wrote:No, they're made to roam the Valleys in huge gangs, terrorizing people with their close-harmony exhaust roar.
Or am I mixing things here?
Funny you should mention that. I watched this last night:
https://www.youtube.com/watch?v=6RhJ5_PPjVM
Postby Puffs » Fri Feb 19, 2021 7:01 am
Old Eastwood - great!
I confused it with this: https://www.youtube.com/watch?v=hnl3N1RQedE
Postby Gerryman Ts125 » Fri Feb 19, 2021 8:10 pm
Ts carb tick over adjustment is the recesed one below the throttle top (in line with throttle cable) the one besides it is the air mix. Some Ts models before 1975/76 had no tick over adjustment.
The picture is of a 1986 model.
Gerryman Ts125
