The bike started first try, and idles fine. But when I drive it up and down the road, it looses power at 2500 - 3000 rpm and makes a strange noise. I tried the choke, but that makes it even worse. Any suggestions?
I cleaned the carbs "so and so": Took of the bowl, it looked relativly clean. So I sprayed carb-cleaner in all the holes og blow through whith compressed air. May be I should have done a more seriouse job?
Tor Johan
