Modified front end?
Postby bry_d » Mon Jul 19, 2004 6:36 am
hello folks here are some pics of of my mz done similar to the one above by the previous owner
Picture 010.jpg (485.65 KiB) Viewed 4082 times
Picture 009.jpg (483.51 KiB) Viewed 4082 times
bry_d
Postby gedge » Mon Jul 19, 2004 8:49 am
Looks good. Ive seen several now that have been done, and its only a matter of time and money before I set to on mine....
gedge
Postby phlat65 » Mon Jul 19, 2004 11:14 am
did you trim the side panels? they look way shorter....
good job! I really like the headlight..
Postby bry_d » Mon Jul 19, 2004 12:27 pm
yes the side pannels were trimmed back a good bit to make the front end look smaller
bry_d
Postby phlat65 » Mon Jul 19, 2004 8:59 pm
do they flex alot without that extra mount point?
Postby bry_d » Tue Jul 20, 2004 10:37 am
no they don't flex about to much as they are mounted pretty strongly plus the plastics pretty thick so should last for gaes even if it did move around a bit
bry_d
Postby keithcross » Tue Jul 20, 2004 1:56 pm
The mod looks good and I have seen 3 bikes done now. One thing worries me though. With the front mounts removed, the mounds left are brass inserts in teh gas tank. If you were real unlucky one of these mounts could be pulled out, causing fuel to be released all over the rider and a hot engine.
Postby phlat65 » Tue Jul 20, 2004 7:56 pm
I still have the front mounts in mine, just cut off the loop that goes to the speedo support.
Previous
Users browsing this forum: Bing [Bot] and 73 guests
