How many turns are you setting the pilot screw?
Postby billr » Fri Aug 06, 2010 9:33 am
Just had an episode of bogging down and poor throttle response...
Went down the list:
Good flow from the tank,
Checked the carbs, float valve filter looked like the lint trap on my dryer (wonder where all that crap came from?)... :oops:
All cleaned up, inline filter installed and it's running well again.
Question is on the pilot screw setting.
I counted the turns to closed (6.5) before I removed it for cleaning.
Put it back in that way.
Checking the manual (2.5 turns) and searching the forum (5-6.5 turns).
It's running and idling fine. I just don't want to cause any problems with it being too rich??
Thanks,
Bill
billr
Re: How many turns are you setting the pilot screw?
Postby basser23 » Fri Aug 06, 2010 10:29 am
Bill,
Shouldn't be a problem....many run 5-7 turns out..you may get exhaust overrun popping with 2.5 to 3...mine does..
basser23
Postby djsbriscoe » Fri Aug 06, 2010 11:00 am
Why not use a colortune kit
http://www.gunson.co.uk/tools.aspx?cat=673
I've got one but I've not used it yet (bit difficult as you really need a dark garage)
Some people here talking about using one
http://www.bikechatforums.com/viewtopic.php?p=1659568
If you try one let us know how it goes.
David.
Electronics tech by trade.
djsbriscoe
Postby billr » Fri Aug 06, 2010 2:41 pm
basser23 wrote:Bill,
Thanks, just wanted to confirm what I read on the search.
djsbriscoe wrote:Why not use a colortune kit
Those were mentioned on another forum I frequent. Had a link to a video of one in use. Considered getting one, but not sure if I'd use it enough to justify...
Cool factor may win out, though...
Bill
billr
