2003 butchered wiring
Postby funmonkee » Sun Jan 23, 2022 2:56 pm
I've had this yellow 2003 for a couple of years.,,actually 3 years, pre COVID...
Just getting around to cleaning it up.
Done the wheels. new discs, chain and sprockets, got some replacement panels. Decided to start it up and had to remove the battery to charge that...
wow what a mess!
It was never great, but once the battery came out it just looks the pits.. . .:-(
I'm using as much internet resources as I can to try to tidy this up. for example the diagrams on https://grahamsmotorcycles.com/mz-parts ... l-devices/ have helped with part numbers. But pretty much knackered with the electrics. it's been hacked about so much.
So,
what would help me, is for any close up photos of under the seat electrics. showing me the difference to this mess ...
funmonkee
Re: 2003 butcher wiring
Postby DAVID THOMPSON » Sun Jan 23, 2022 5:00 pm
link below
and more by doing a site search for tony idle
he did some fine drawings of the wiring system
and relay 19 and relay 30 its the main relay on the 4 cycle 660 and 125
cc bikes
for color coded wires to repair with visit a late model German car a a local parts breaker
crimp connectors suck solder them on the wire
the school system has failed to teach BASIC electrical skills world wide the word mess is what you see under the seat
of most bikes
viewtopic.php?f=3&t=8130&p=42882&hilit=tony+idle&sid=a95da366f11e102ea455a8c4d5f464d9#p42882
Postby funmonkee » Sun Jan 23, 2022 5:31 pm
Thank you for the reply.
It's been a years since I've been active here :-)
Should be a basic common sense that things should be extended and not mutated and hacked to death :-)
I've spent a fair bit to get this bike clean and almost ready for the road. If I'd looked at the battery and electrics first, I would have given up at the start.
Just not sure where to start. The headlight works; clock lights, for headlight on and full bean work. The indicators are dead. The rear tail light is on; but no activity when I use the rear or front brake.
With a fairly new battery attached; it tries to turn over. There is fuel will need to get the plug out and see what state it's in.
I'll look for the post by tony idle
Cheers
funmonkee
Postby DAVID THOMPSON » Sun Jan 23, 2022 7:38 pm
be careful with the carb // on many there is a filter just before the float needle
do not break the post on the carb getting the float pin out to clean the fuel line
inlet the float is in the way of getting the needle and seat with filter out
Dave
Postby funmonkee » Tue Jan 25, 2022 5:46 pm
looking to confirm which component this is on the attached... electrics schema
Which relay is this ?
which relay is this?
funmonkee
Re: 2003 butchered wiring
Postby DAVID THOMPSON » Wed Jan 26, 2022 10:16 pm
the green wire gives it away its relay right in the lower middle
of the wires drawing and carries every thing it is relay 19
when it closes at power on the red black and red white get connected
and the bike is on
the green wire goes to transmission switch
Postby breakwellmz » Thu Jan 27, 2022 5:15 am
funmonkee wrote:I've had this yellow 2003 for a couple of years.,,actually 3 years, pre COVID...
wow what a mess!
So,
Hi.
Do you still want photos? Out in the garage later so can take them of my 2004 Mastiff.
Cheers
Postby funmonkee » Fri Feb 04, 2022 3:45 pm
Would be useful yes.
Would be good to see something other than my mess
cheer
funmonkee
Postby breakwellmz » Sat Feb 05, 2022 8:23 am
Hi.
Hope this helps, not the best of photos i`m afraid -
Cheers.
Postby funmonkee » Sun Feb 06, 2022 2:29 pm
thank you. that looks very clean
TBH I'm getting sick of spending time and money on this bike.
anyone look for a clean example; but butchered electics... take it?
funmonkee
Postby DAVID THOMPSON » Sun Feb 06, 2022 3:50 pm
if a bike is past its second owner its probably got a
mangled wiring harness
i bought several bmw bikes 55 to 1980 because of butchered wires
the only reason was the guy working on it did not know squat about wiring
or to read the book on how to get the magneto timed proper
Dave
Postby breakwellmz » Mon Feb 07, 2022 2:56 am
funmonkee wrote:thank you. that looks very clean
No worries.
Clean, really? I`m not one for cleaning and the wiring hasn`t been touched from new because it hasn`t needed it to be honest (new in 2004)
Perhaps you ought to step away from it for a bit before coming to a firm decision, i think you`ll get hardly anything for it as it stands.
Happy to supply further (and better quality!) photos if and when needed.
Cheers.
Postby Rizla215 » Sun Jun 26, 2022 10:09 pm
You call that butchered? May I submit:
Rizla215
Postby Rizla215 » Sun Jun 26, 2022 10:10 pm
There’s more…
Rizla215
Postby Puffs » Mon Jun 27, 2022 3:14 am
Users browsing this forum: Bing [Bot] and 30 guests
