Hey breakwellmz.
Your setup looks really nice !
I didn't know that was the case with the grizzly manifold
I already have a BSM end can on the bike and have changed the main jet on the main (small) carb from a 130 to a 135 with the mixture screw 5 or 6 turns out I cant remember exactly, the bike runs great and can consistently hit 95mph, though I would really like it to pull the front wheel up in 1st and maybe 2nd more.
Basically as much torque as I can get from it without drastically affecting it's reliability.
With your setup, would the missing carb not cause issues with lower air volume entering the engine ? Of course the air now has a much greater velocity which probably outweighs the lower volume especially when the throttle is open. Also, what is the copper tube to the other intake actually doing ? It seems like its at a very odd angle and would struggle to capture much air and fuel from the other intake boot but of course it works for you !
And finally, what kind of jetting are you running ?
I am not very experienced with this kind of thing so if I am talking total rubbish please tell me, just letting my brain run and spitting out the results
