Please would someone in the UK get me the prices of Baghira/BP/SM right tank cover and front mudguard, or point me to a dealer (online or fax) ?
(I know they're expensive, I just want to know how much.)
keithcross wrote:Not sure how much but try BSA Regal in Southampton. They have a web page and acept all major credit cards. They are also OK with sending parts abroad.
keithcross wrote:I quite like the look of the panels on the first picture, kinda like the effect that I want. Just wont cut down my original panels until I get spare ones.
Fil wrote:I like the look of those modified rad panels in the top picture! It would be perfect if the panels could be extended to cover the bottom part of the radiators.
I've just cut down my rad panels so I could get rid of the tubular frame on the front of the bike. Looks much better, but I need to attach the panels to the rads to stop them flapping about
cat wrote:The 'tubular frame' you removed - the bar by the headlight? it's not ..a fixed part of the frame, surely not? i mean did you have to cut it off or can it be unbolted?
Fil wrote:cat wrote:The 'tubular frame' you removed - the bar by the headlight? it's not ..a fixed part of the frame, surely not? i mean did you have to cut it off or can it be unbolted?
You can just unbolt the weird framework that goes from the down tube (just infront of the radiators on each side) to the bar just above the headlights (I have a Mastiff, not a Baggy). The upper part of the radiator shroud has two screws that attach to this framework. The only thing I had to 'cut' were the plastic panels themselves.
keithcross wrote:Fil
On my Baggi the frame that supports the tank panels is a 2 piece unit. Left hand and right hand, bolted in the middle. The bit that supports the tank panels is welded to the bar that goes on to support the frame work for the speedo and headlight assembly. To support the tank and get rid of the bars that carries on requires the tubes to be cut.
