Rear spindle/axle which way round?
Posted: Fri Jan 29, 2021 3:46 pm
Hi.
I took the rear wheel off the Mastiff well over a week ago now, and today went to refit it together with its new sprocket and bolts, cush drive rubbers, axle nuts,polished rim and hand fitted new tyre.
One end of the axle is threaded longer than the other by about 10mm, does it matter which way round it goes back thru the hub? I`ve only had it since new.
Cheers.
Cheers.
