front end
Hi.
Sorted my front end. removed the nudge bars frame assembly what ever you call it and bolted the headlamp using a headlamp bracket from m and p must say a big improvement to the front end all I had to do was make a bracket for the speedo which was just a u piece of aluminium. bit of a pain to hold it all in place and route the cables, the halogen bulb connector is very close to the ignition switch and the clutch cable is not quite routed properly yet but all in all will be an improvement, just need to get my self some mini indicators. Anyone fitted led indicators to front end do they need the seperate flasher unit or will they work o.k. will post some more pics when weather improves..
