IT WAS THE CHOKE
Hi and THANK YOU
You guys where spot on with your diagnosis, seems it was the cold running jet (choke) mechanisim sticking.
I changed the oil as there seemed to be fuel mixed in . Cleaned the choke going into the carb as suggested.And so far so good .
You guys saved me some money .Thanks for being so generous with your experience and knowledge.
I do have one more hopefully not too stupid a question. At the top of the rubber overflow pipe at the bottom of the carb is a screw (wich i somehow have successfully managed to strip ) in the closed position ,will the overflow still work? Is the screw usually left completly closed unless draining the carb ,i would venture to say yes.
Thanks again
steve
Thanks again
steve
