Baghira starting issues
Posted:
Fri Apr 04, 2008 4:11 am
by valerian
any advice on this gratefully welcomed
really struggle to get it to start
Re: Baghira starting issues
Posted:
Fri Apr 04, 2008 12:52 pm
by handsomejackuk
Check out my post 10 threads down "cold starting an issue" inlet valves had closed up, reset them to .15mm also new plug new air filter, removed choke from carb and lubricated, may have been stickking. What i noticed was bike just puffed and farted and would refuse to start at all when cold. Now starts first time on the key full choke on starting no throttle leave it run for a minute then turn off choke. worked for me. Not had chance to check exhaust valves yet but suspect that they may need adjusting as well. bike has done 9300 miles since new I service myself so maybe skipping the 6000 mile valve chack was what did it give it a go hope it works for you...
Alun
