bright ideas
PostPosted: Mon Aug 04, 2008 5:42 am
by 6274rico
hi all,can any body tell me if there there is a brighter dipped beam bulb i can fit to my 98 skorpion traveller , with out causing generator issues ? if so uk suppliers,also is there a oil prsssure warning bulb on dash panel. cheers steve
Re: bright ideas
PostPosted: Mon Aug 04, 2008 11:23 am
by DAVID THOMPSON
is there a oil pressure warning bulb on dash panel.
if there is it should come on when key is turned on
and go off when bike starts
if not bad bulb or disconnected from pressure switch
not into bulbs but there are some out there
but do not get to high wattage if in area that requires head lamp
all of the time
the problem is the too small battery's and no space in the battery box for a bigger one
my solution to the too small battery on bikes... is let the engineers
decide what size it should be .... then the head man tell them to make the battery
box big enough to fit a gel type that is twice that AH rating :smt040
Re: bright ideas
PostPosted: Mon Aug 04, 2008 3:14 pm
by Sue
Not sure if this helps... got a brighter bulb from my local Halfords, (for my Baggi) same wattage but brighter output - and its spot on. They had a huge selection both in the car and bike section.
Sue
Re: bright ideas
PostPosted: Tue Aug 05, 2008 6:34 am
by 6274rico
cheers for that ,ill check bulbs & connections for oil swithch, & check out my local halfords for a beta bulb, steve. :D
Re: bright ideas
PostPosted: Tue Aug 12, 2008 6:33 pm
by daytona
The battery is just for cranking the eng! You rotor/stator is what should power everything after its running! Also recharge the battery after. Silverstar bulbs use the same amps but put out more watts of light, or more usable light anyway. better bulbs do the trick.
