Grimeca rear brake info
Hi there,
Just after a quick bit of info regarding the rear Grimeca bleed nipple on my Skorpion Sport. Whilst attempting to bleed the brakes, I managed to round off the rear bleed nipple with a wring spanner. Now I will have to remove the banjo bolt to fit a socket over the nipple to replace it.
Firstly, anyone know if there is a generic replacement bleed nipple I can purchase. When re-assembling the banjo assy will I need to replace the washer between the Banjo and caliper. What would you re-torque the Banjo assy back too. And what would be the best method of re-filling the brake line with fresh fluid.
Managed to bleed the front caliper with no problems. Fluid in the rear caliper looks like syrup. A job I have wanted to complete since purchasing the bike a couple of years ago.
Stu
Stu
