weird electrical issue...any ideas?
Skorpion, new to me. 12,000 miles. Stock but for some jetting.
Original problem:
Normally would start up fine..no issues. Then, for no apparent reason, I'd press the start button, the the solenoid would click, but the engine wouldn't turn. When this happened the headlight stayed off, no power anywhere...the bike was just plain dead. Nada. Nothing.
While having this issue I found the battery voltage would be fine (12.7 +) with the ignition Off, but when I turned the key to the On position the battery voltage would drop to 0.5.
This seemed like a short to me. But then suddenly earlier today while poking around with my meter, everything went back to normal and I didn't have anything to test for.
So now, tonight, I got that same problem...then I fiddled with things a bit and the lights came back on and the engine cranks, BUT I now have Zero spark. So similar end result...can't ride and I'm stranded.
Anyone here have a solution for these gremlins or am I in for a New Wiring Harness?
Any and all ideas/help greatly appreciated
Thanks,
Adam
Original problem:
Thanks,
Adam
