Carb.... again
Posted:
Sun Oct 25, 2009 3:34 pm
by elcaptain69
I have always had a degree of carb problems.. never too serious but always wanted better.. well I've had a bit of a problem with the bike cutting out when I stop at junctions etc. or if I did an abrupt stop.. well I have always played around with the secondary carb but I knew this was a primary carb problem, so decided to notch the needle up (clip down 1) More fuel.. well its made all the difference and loads quicker off the mark.. The good news is that it can be done with only taking the tank off and not the carbs.. 20 min job!
Re: Carb.... again
Posted:
Mon Oct 26, 2009 1:40 am
by Craig43
Thanks for the info, mine does exactly the same, will try your remedy
Craig
Re: Carb.... again
Posted:
Mon Oct 26, 2009 11:18 am
by elcaptain69
Ok Craig... If I can help give me a shout.. I thought this might be a common problem, thats why I posted it.. Like i said it can be done without taking the carbs off, a bit fiddley but worth it.
Re: Carb.... again
Posted:
Thu Oct 29, 2009 1:54 am
by Craig43
Great looking bike, where did you score the rear light? also I am looking for some rubber clamps or similar to attach headlight and assembly to front forks so it turns do you have any ideas?
Craig
Re: Carb.... again
Posted:
Wed Nov 04, 2009 4:07 am
by elcaptain69
HI again Craig, I got my rear light from these guys..
http://www.busters-accessories.co.uk/pr ... ghway-Hawk Its in the UK but i'd imagine you'd be able to get something in your neck of the woods. Ive fitted L.E.D bulbs in it..
http://www.1topstore.com/product_info.p ... ts_id=6456 available from most retailers now.. they are great.. well bright and shock proof!
I did a quick search about the headlight mount.. google through up this...
http://images.google.co.uk/imgres?imgur ... N%26um%3D1Ok its on a Bandit but probably give you some ideas..
Its getting to cold winter here
so not using my Baggi so much but its running really good now and not cut out at all since I did the carb
Re: Carb.... again
Posted:
Thu May 13, 2010 3:49 pm
by Taipan
I think I need to do this as my bike stumbles a bit when opening the throttle. How do you get the slide out of the primary carb without removing the carbs to get the throttle spindle assembly out?
