Brembo P4 30/34 caliper is too wide on Baghira?
Posted:
Sun Jul 04, 2010 3:51 am
by cat
As per subject line:
Is the Brembo P4 30/34 caliper is too wide on Baghira?
Baghira, not Skorpion. Try as I might, reading and searching for hours, I have not been able to get a definitive answer.
Could we not just get a clear list of what fits, what is actually available and where...?
Re: Brembo P4 30/34 caliper is too wide on Baghira?
Posted:
Sun Jul 04, 2010 3:58 am
by Bill Jurgenson
probably not, but doesn't fit without an adapter plate, same as on a KTM.
A friend rides a tuned Baggi. I'll ask him.
Posted:
Mon Jul 05, 2010 11:50 pm
by Bill Jurgenson
I was right about KTMs. With spoked wheels there is lots of room and replacing the the floating caliper with a P4 is a favorite "past time." The milled adapter is easily gotten and the situation cannot be any different with a Baggi with spoked wheel.
Posted:
Tue Jul 06, 2010 3:37 am
by cat
Thanks, Bill. Given that one does have to use an adaptor mount, that moving it further away from the mounting points on the forks also moves away from the spokes at the hub. I think I'd originally thought that they mounted directly to the [40mm] mounting points on the forks because I'd confused it with what I'd read abuot doing it on Skorpion. (That the Skorpion has the 40mm distance mounting and the Baghira does not...?)
