Baghira BP carb issues ...
Hello all,
I've got a carb problem on a baghira thats been standing around unused for 6 months.
I've searched the forum and it looks like its a common problem, so I've had the carbs off for a look.
Theyre a damn tight fit to get off with the motor still in. Figured out I need to pull the rubber inlets into the air box and then just wiggle!!
So, I've had everything apart and blasted through with carb cleaner, took out every brass bit I could see and cleaned it through...
You can see lots of 'gum' in the float bowl....
So can I ask, where is the pilot Jet in the pictures above???
Seems impossible to find a diagram of these carbs anywhere!!!
Cheers,
Dave.
Cheers,
Dave.
