Overdue Maintenance
I have a 2001 Baggy which I have ridden for three years with minimal maintenance (oil, filter, plugs). It is now time for a serious going over.
It has always used a lot of oil with no sign of a leak and no smoke from the exhaust, so god where it’s going. It has had, for the past couple of years, an annoying clanking noise from the engine, intermittent (not every stroke) but frequent. Hasn’t affected performance or starting though.
So the first of what I suspect will be a number of questions.
I have the carb and rads off, the two side covers and the rocker cover. Can I take the head and the barrel off with the engine in the frame?
The main drive nut on the crank on the clutch side is lose (the cog can move in relation to the crank. Should this be tight?
Any tips on progressing? I am nervous about the timing particularly.
All assistance appreciated.
Stuart
Stuart
