Chain and sprocket and my bike's general check up
Hey guys,
After having a bit of a check up, it appears that my skorpion requires (amongst other things) a new chain and sproket. Particularly chain, but since the chain looks like it has been badly worn for some time, and this may mean sprocket damage, better to replace it entirely. The current sprocket set up is the standard 15 front and 39 rear. The chain is 520-110 links.
As I am going to replace it, does anybody know where is the best place to get this part in the U.S. West Coast (California) and if I should stick to the standard chain sprocket set up, or go for another set up. What are the advantages of different sprocket ratios? I'm guessing a smaller front sprocket and larger rear one makes for a sportier fast acceleration performance? I'm not interested in crazy speed or acceleration. I plan to use the bike for some distance trips, so maybe the standard set up is best for that? I'm hoping I can fit the new sprockets and chain myself, if its not too big of a job. Anybody with experience doing this job and do they think its realistic for someone new to bikes? Apologies if my questions are dunse in anyway, I'm a complete newbie.
Other things I will need to replace on the bike are:
Engine breather hose
Front brake lever
There was one feature of the bike which the mechanic who did the check up couldn't get his head around. He said that a pipe connected to the carbs was designed to let fuel out of the carbs when they got to full, but that this part (an electrical black box) shut off when the bike shut off, which meant it couldn't do its job when bike was off. He said this just meant I had to make sure that I always turned the switch allowing fuel from the tank into the carbs to off when the bike was turned off. This isn't really a big deal, just something he said, and I was curious about it. I will read up about it myself soon when I take a look at any parts and maintenance documents I have. The mechanic was a nice guy, he understood I was a student on a low budget, and he was just advising me what needed to be done so I could go about doing it on my own. Theres nothing very major wrong with the bike, so overall, I'm pretty happy with how it went.
Front brake lever
