Petcock filter removal on 2000 Tour
This bike has 3k miles on it so it sat a lot and all things considered it's been reliable around town here except for one stalling issue where I got it home on full choke which is the only way it would run. I've been reading the applicable posts and am starting to follow the advise given, starting with the petcock filter. I removed the bowl and when I look up I see a round white screen filter. My question is how to remove it so I can see if any crud has collected on the other side. Do I just pry it out from the sides or from the plastic hole in the center of the screen. I'd also like to put a small inline filter from the petcock to the carbs in the short run of fuel line I can access without pulling the tank. Any input would be appreciated. Jim
