First ride...
..after tuning hopping my Skorpion up exactly the wrong way: new rod, rebalanced crank, SZR first gear(thanks Bill) , 11:1 piston, porting (by someone who knows this head), cam....and stock intake and exhaust. Well, mostly stock - a Tunebike spacer in the carb, and I tore the exhaust apart, ground all the *huge* internal welds down, and tig welded it back together,
It started up just like the stock motor, and around town pretty much sounds and feels the same as the stocker, except that it just keeps going harder and harder from about 4k rpm on up. Sure makes a nice sound up around 6k on full throttle too. It will be a little while before I start regularly wringing it up at higher RPMs, but I don't think it's going to run out of steam till it hits 7500 rpm. The tall first gear is great. You barely notice the higher gear pulling away, but then 2nd is right where it should be.
Hard to say what the power output is, but in the 4-5,000 RPM range I'd guess it's not more than 10-15% better than a stocker. Up higher its a *lot* stronger, but I haven't spent any real time riding in that range yet, and I do need to do a little mixture and timing work. I'll try to ride it around a bit like this and then dyno it in the spring.
Just what I wanted.
Sam
Just what I wanted.
Sam
