Is the skorpion cylinder nikasil coated
The title says it all. Is it regular steel ? or nikasil lined.
Thanks.
Srinath.
Thanks.
Srinath.
https://wew.mzriders.com/
Hajok wrote:Regular steel it is, so you can swap your melted piston with any oversize: 101 mm, 102 mm, 105 mm... NiKaSil coating is only used directly onto aluminium cylinders using a kind of anodising process. This gives better heat transfer, the same expansion coefficent as the piston and therefore smaller tolerances are possible.
Any 5 valve yamaha piston will do; XTZ, SZR, Raptor.
Question is: what cause is melting your engine?
