Jumps out of gear
My Skorpion Sport is jumping out of 5th gear. it happens at higher speeds (+120 km/h) and it goes directly in 4th, causing the engine to go into the rev. limiter for a second (untill I've pulled the clutch). At begin it did only at +140 km/h but lately it is happening more and at lower speeds. So it is getting worse.
I already have a ∅8mm shift lever linkage instead of the original ∅5mm. At first I thought the original was the problem due it's flexibility, but it isn't.
Is there anything I should check first before pulling the gearbox apart?
