Front brake gone bad On Baggie
My 2001 Baggie only has around 3,500 miles on it, and the front brake has started getting mushy and letting the level come to the handle bar. It has been sitting a few months, and today it was much worse than before, to the extent it wasn't doing hardly anything until pumped a few times, and then it was just real weak. One of the last times I rode it, I did a quick bleed by pumping it up and opening the caliper nipple. I expected to see some air, but none was apparent. It didn't change.
So today I took off the Master Cylinder lid, and fluid was up to the top. It was a little brown, but you can still see through it good. When I squeeze the lever though, it shoots a squirt up through the bottom hole that is closest to the center. Opening the bleeder nipple lets fluid drip out, but when squeezing the lever it only shoots out in a weak stream, and I expected it to give strong squirt.
I am pretty sure it is the master cylinder that will need to be disassembled and cleaned, but has anyone else had this problem?
