SZR engine in Skorpion - top engine mounting
Posted: Sat May 10, 2014 4:02 pm
I am currently busy swapping the original engine in my Skorpion with an engine from a SZR.
The Skorpion engine was mounted at the top with two short bolts and two nuts. The nuts mounted inside. Like in the next picture:
But the nuts don't fit in the SZR engine because that particularly area is much smaller. As you can see in the following picture:
Now I thought about putting just one long bolt through both holes. But will this need a inner spacing bush? Because I am afraid the cylinder head cover could crack if you squeeze those two mounting points together?
I've tried looking in the part list is of the XTZ and SZR if those bikes have just one bolt there... But it unfortunately those part lists aren't very clear to me.
