95 MZ Skorpion Sport project
Posted:
Sat Dec 20, 2014 12:06 pm
by miteybites
Re: 95 MZ Skorpion Sport project
Posted:
Sat Dec 20, 2014 1:32 pm
by miteybites
Posted:
Sat Dec 20, 2014 3:50 pm
by edfmaniac
How did you check compression? Bike looks like it sat outside near the ocean for a long time but that shouldn't be a problem if you are going through everything(wiring harness, ALL bearings in the wheels/suspension/steering stem).
Posted:
Sat Dec 20, 2014 6:54 pm
by miteybites
I just felt the compression when turning it over with a rachet. I'll get actual compression numbers once I throw a battery in it. And you are correct. The bike sat outside in pacific beach in San diego. The subframe has no paint left on it, which is odd because the frame is pretty clean. Must be lower quality paint used on the subframe.
Posted:
Sun Dec 21, 2014 6:37 pm
by miteybites
Started tearing into the carbs. Tried removing the needle jet holder and the top snapped off. Then came out the easy outs and pb blaster. Then added some heat. The thing would not budge. Broke my easy out, my tap handle and cracked the body of the carb. I'd say it's pretty well stuck. So looks like I'll be sound a 41mm single carb conversion.
If anybody needs these carbs for parts let me know.
Posted:
Mon Dec 22, 2014 2:21 am
by edfmaniac
This bike has a decomp system so you don't get any compression at all until the engine gets above a certain RPM. You were likely just feeling the valve springs being compressed.
Sorry to hear about your jet issue. Good luck with the single carb mod. Intake manifolds are hard to come by unless you are making your own.
Posted:
Wed Dec 24, 2014 6:03 pm
by billr
miteybites wrote: So looks like I'll be sound a 41mm single carb conversion.
Check this thread
Single Carb conversion.
Don't need a manifold.
Might be feasible?? Interesting, anyway. I'd try it if my stockers go south.
Bill R
Posted:
Thu Dec 25, 2014 7:35 pm
by samandkimberly
fWIW, I've got a clean set of stock carbs with a Tunebike kit iintalled and set up; perfect for a stock or mildly tuned engine...
100 bucks?
Sam
Posted:
Fri Dec 26, 2014 10:09 am
by miteybites
Actually I already bought a rhino 660 carb for $48 and a grizzly manifold for $18 on eBay. I'm not sure if I'm going to machine and weld on a new flange or try to make an adaptor plate. I'm a machinist and I have several machines at my disposal during off hours. I also plan on doing some custom billet adjustable rearsets. Might also do a billtet tripple tree just for fun, depending on how the fork swap goes. I've been trying to find inverted forks that are the same length or very close so I don't change the suspension geometry.
I measured the stock forks at 29.5" which would be 749mm.
What I've found so far:
06-07 gsxr600,750 738mm
Zx636 750mm
06-07 zx10r 743mm
Posted:
Tue Dec 30, 2014 4:27 am
by miteybites
Picked up a used set of raptor 700 crank gears on eBay for $5.99 shipped. Can't beat that. Anybody know if the raptor 660 side cover gasket is the same as the MZ?
