Page 1 of 2
fuel consumption on mz 660
Posted:
Sun Feb 01, 2015 12:11 pm
by Dewald Malan
I just got a mz 660 and it seems to be running a bit rich on fuel im only getting 14km per 1l. does anyone have any advise on what i should do to improve this.
Thanks a lot Dewald Malan
Re: fuel consumption on mz 660
Posted:
Sun Feb 01, 2015 1:18 pm
by DAVID THOMPSON
mine has always been hard on a tank of fuel
but have not had time to sort out why!!
Posted:
Sun Feb 01, 2015 1:44 pm
by breakwellmz
That`s about 40 mpg(Uk) by my reckoning.
Posted:
Sun Feb 01, 2015 1:58 pm
by Dewald Malan
I have a aftermarket exhaust on. should there be any setting done to the carb because it does smell a bit rich as if its running very heavy on fuel. I have had a look on the reviews and specs and i should be getting 17 km per L. how many km do you guys get on a L
Posted:
Sun Feb 01, 2015 9:57 pm
by DAVID THOMPSON
mine goes about 95 miles and needs a fill up so i am thinking about 35 mpg in USA gallons
at 115 miles mine becomes a pusher but i am getting to old to push it..
do not forget to put tank lever back in the run position after fillup
so you do not run out and discover you have no reserve
its a pain parkersburg wv to clarksburg wv at night requires you carry 2 gallons in the
buddy box taking up space you need for other stuff because of a lack of open service stations
Posted:
Mon Feb 02, 2015 1:46 am
by Dewald Malan
thanks a lot for the help and reply.
Posted:
Mon Feb 02, 2015 3:45 am
by breakwellmz
Dewald Malan wrote:I have a aftermarket exhaust on. should there be any setting done to the carb because it does smell a bit rich as if its running very heavy on fuel. I have had a look on the reviews and specs and i should be getting 17 km per L. how many km do you guys get on a L
Have you checked that your choke is not sticking in the on position? Is it likely that someone has been inside the carb and maybe overcompensated for the freer flowing exhaust by going up too many sizes on jets, what is the sparkplug colour like?
Posted:
Mon Feb 02, 2015 5:27 am
by arry_b
It should get a lot better than that. My Skorpion is more economical than my ETZ150!
My Traveller has never got below 150 miles from full to reserve even when riding enthusiastically. I have got 200 miles on occasion on tour before hitting reserve.
Posted:
Tue Feb 03, 2015 9:04 pm
by jaywillie2912
Rode my Baghira from Orlando to Tampa to Orlando.....mileage of 51 mpg with a gearing of 15/43 riding between 70 & 80 mph maybe.
Hope this helps.
Posted:
Wed Feb 04, 2015 8:22 am
by clem27
I generally get to 180 miles before I have to switch to reserve. I have the single carb conversion but I am not sure of the sprocket size. I did go up a size in tires but my speedometer seems fairly accurate. Tachometer is dead though.
Posted:
Fri Feb 06, 2015 2:23 am
by Dewald Malan
breakwellmz wrote:Dewald Malan wrote:I have a aftermarket exhaust on. should there be any setting done to the carb because it does smell a bit rich as if its running very heavy on fuel. I have had a look on the reviews and specs and i should be getting 17 km per L. how many km do you guys get on a L
Thank you very much for the reply
I havent checked the sparkplug yet. Me and my brother-inlaw are busy setting the carb. Could it be that the fueling screw on the carb is open to much?
Posted:
Fri Feb 06, 2015 2:25 am
by Dewald Malan
arry_b wrote:It should get a lot better than that. My Skorpion is more economical than my ETZ150!
thanks for the reply im really happy to hear that its not normal for it to be so heavy on gas because im planning on touring trough the country of Lesotho with it.
Posted:
Fri Feb 06, 2015 2:26 am
by Dewald Malan
jaywillie2912 wrote:Rode my Baghira from Orlando to Tampa to Orlando.....mileage of 51 mpg with a gearing of 15/43 riding between 70 & 80 mph maybe.
Hope this helps.
Posted:
Sun Feb 08, 2015 1:59 pm
by Dewald Malan
what jets should i get for the bike will the raptor 660 main jet be okay. I live 1200m/ 4000feet above see level
Posted:
Mon Feb 09, 2015 1:43 am
by Dewald Malan
