Tranny problem diagnosis
PostPosted: Mon Mar 23, 2015 6:56 pm
by roughridnsob
First of all the bike is a 2000 MZ Baghira 660 supermoto. I was cruising along to work today at around 70 when the back tire decided to lock up on me. I was able to keep it on two wheels thank god and skidded to a stop on the side of the road.
Symptoms:
-Tranny is locked in gear, wont go into neutral
-Clutch pulled in it will start normally but when clutch is let out it bogs and dies
-with engine off and clutch pulled in it will not roll
-if I mess with the gear shift and rock back and forth I can get it to go maybe 1-2 feet before it locks up again (still wont go into neutral)
I'm thinking I may have blown 5th.
I have read the bottom end on the MZs are different than yamaha how would I go about replacing gear sets.
any help or advice is greatly appriciated. Thank you
Re: Tranny problem diagnosis
PostPosted: Mon Mar 23, 2015 10:30 pm
by edfmaniac
Bottom end is all Yamaha. You just need to find the right parts and ratios. My guess is that the XT600 gears would work well for you.
PostPosted: Thu Mar 26, 2015 7:06 pm
by breakwellmz
Hi.
Sorry if you have already thought of this, but have you discounted a rear axle bearing seizure ?
Cheers
