Vario adjustable footrests Sport
Hi folks, I fitted these adjustable footrests which are adjustable in the vertical plane through 360 degrees. The inner part which fits into the clevis needed filing down slightly, easy since it was aluminium and a thin metal sheet about 1mm needed riveting to the inside of the clevis to make the rests stay horizontal. I had to do away with the inner round spacers in the spring and drill out the rivets on the original clevis pins. A pair of 35mm long stainless M8 pins with new washers and split pins fitted well, straight through the clevis holes and the Varios. Now I have a good riding position, lower footpegs along with the VFR750 bars for a more upright position
