transmission kill sensor??
Posted:
Fri Jul 08, 2016 7:56 pm
by bobmac7835
Just got a 1995 Skorpion. It starts and runs fine, then you stop for fuel or whatever and it starts fine but when you engage first gear all power shuts down. After while all is well until you stop then same thing happens. Any ideas as to the problem?
Re: transmission kill sensor??
Posted:
Fri Jul 08, 2016 10:13 pm
by edfmaniac
Maybe a faulty kick stand safety switch? That's the only thing that should kill the engine when you shift it out of neutral that I can think of right now.
Posted:
Sat Jul 09, 2016 7:10 am
by droy
Agreed
If you don't want to replace it just cut the two wires and twist then together and ci=over with a bit of electric tape.
That said I have a few of these switches in my spares pile.
Posted:
Sat Jul 09, 2016 10:58 am
by lavrentyuk
Couldn't agree more. The one on my Skorpion hasn't gone wrong yet but I am aware that it is only a matter of time. They collect crud from engine and road, the one fitted to my Cagiva was suspiciously similar and I eventually took it off. Just don't leave the side stand down ! DAMHIK !!
Posted:
Sat Jul 09, 2016 6:43 pm
by bobmac7835
Thanks for all the help! My other bikes are 60's ergo no sensors, only censors.
Posted:
Mon Jul 11, 2016 5:30 pm
by billr
lavrentyuk wrote: Just don't leave the side stand down ! DAMHIK !!
Been there...done that...
Bill
Posted:
Mon Jul 11, 2016 6:02 pm
by DAVID THOMPSON
the side stand switch controls the main relay 19 0n the 125cc bikes and relay 30 on 660 engine bikes
the oem relay is too small and it carries all the power for the whole bike except main power for starting
see this drawing Thanks to tony idle
click on it a couple time to make it bigger PRINT A COPY FOR THE WORK SHOP INFO WALL
Posted:
Wed Jul 20, 2016 5:16 am
by Muzzyrider
If the relay is too small then should it be changed for a bigger capacity one?
Niall
Posted:
Wed Jul 20, 2016 11:27 pm
by DAVID THOMPSON
this relay can be replaced with one from a car parts store
but all the associated diodes and switches need to be in working order
this relay is a major cause of many people hauling a bike home
good luck fo
search for relay30 or withe a space
