rectifier/regulator bad or not?
Greetings,
Had my charging system checked during 5K mi. Service because my 2002 RT125 eats batteries. They said to replace the recto/reg, because the charging system was "weak". Wanting to confirm b4 shelling out $$ for the part, I checked voltage at battery teminals, running, batt freshly charged (it was low @ shop). Hovered around 13V @ 3000rpm, up to 14V @ 9000, with lights an everything. That's only half a volt off spec. Think it's worth buying the part? I'm skeptical. I have to take it somewhere else to check the connectors & wiring--can't take off tank where I live, and that stuff is under the tank. Advice?
~Paul
~Paul
