TS250 indicator bulbs
Postby paulo » Thu Aug 28, 2008 12:45 pm
Could anybody please tell me the correct wattage for the indicator bulbs on a TS250. MIne is currently running 6v 15w bulbs but my very old Haynes manual suggests 18w. Anybody?
paulo
Re: TS250 indicator bulbs
Postby DAVID THOMPSON » Thu Aug 28, 2008 10:10 pm
watch the flash rate if it seems fast use smaller wattage bulbs
and other info on speedometer lamps
some of the old bmw bulbs were 6v 1point 2 watts 1.2w
and they were tooo bright some times
hope this helps
this is the one that lights the speedometer
the one for the charging light must also be correct in some bikes or it will mess up the charging
Watts: 2W
Amps: 0.33A
Volts: 6V
Base: BA9S SINGLE CONTACT BAYONET, 9MM DIAMETER
Length: 1.00 Inches ---- 25.4 Millimeters
Life: 200
Bulb Shape: T2 1/2
Bulb Finish: CLEAR
Photo of Item No. O-3895
Product Information and equipment used in (Partial List)
ALBA 901-99 O-3895
JENA 17043 O-3895
LUCAS 287 O-3895
NARVA 17043 O-3895
OSRAM SYLVANIA 3895 O-3895
OSRAM SYLVANIA K5631 O-3895
PHILIPS 6913 O-3895
STANLEY 1362 O-3895
the one below in my bmw spairs
OSRAM SYLVANIA K5631 6v 2watts
