TS250/1 swinging arm spindle removal
Postby rightsideup » Thu Jun 19, 2025 2:09 pm
I know that they are notoriously difficult to remove but, after two weeks, I am at an impasse when it comes to the removal of my swinging arm spindle.
I've used endless WD40, hammers and using the spindle nut to pull the spindle (now stripped) - in total I'd say it's moved 15mm.
I'm at a loss what to try next?
'74 Ducati 750GT | '78 MZ TS250-1
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.
rightsideup
Re: TS250/1 swinging arm spindle removal
Postby Puffs » Fri Jun 20, 2025 3:19 am
I never had, or worked on a TS, but to frame the situation (click to enlarge):
I suppose inner bushes 1 (right, 54mm long) an/or 2 (left, L=44mm) are rusted onto the spindle 11. The swingarm has no bearings, it has a rubber bush (4 & 5) between the steel inner bushes and the swingarm. The construction is similar to that in the later ETZ, and should in principle be maintenance free. But in practice, if the rubbers are gone, you're up the brown river.
I once had a similar issue with an SP400 swingarm axle/spindle (because the previous owner failed to put decent grease on the axle at assembly), which eluded me for years. After many failed attempts with hammers (while supporting the opposite side with weight), copious amounts of WD40, and indeed a torch, in the end I managed to get it out by pulling. I used the thread on the shaft to pull the shaft, by putting ever longer bits of pipe below it. Sounds like you already tried something like that. If your thread has already been stripped, maybe you can try drilling a hole and tap thread into that? Pull, in combination with tapping from the other side, and WD40. Good luck!
Another pic from the TS251 manual:
Postby Jay Bee » Sat Jun 21, 2025 4:50 am
WD40 is a water-displacing fluid/lubricant, and next to useless as an effective penetrant.
Get some PlusGas formula A, made specifically for this task.
Jay Bee
Postby Puffs » Sun Jun 22, 2025 3:09 am
By all means, try any product available, but I politely disagree on the qualities of WD40 sir. I think it's exactly aimed at something like this, and normally quite effective.
Only, the place it has to reach is quite deep, and difficult to get at. What might help is trying to get some help from air pressure, for instance by, after spraying penetrating oil, try to blow it in the creak with an high pressure air gun (spray - air - spray - air ...). Or maybe you can fit something over it, to build-up some pressure & force it in? Both sides.
Postby rightsideup » Sun Jun 22, 2025 7:52 am
Puffs wrote:I suppose inner bushes 1 (right, 54mm long) an/or 2 (left, L=44mm) are rusted onto the spindle 11.
Funnily enough these bushes aren't seized on the spindle - they move freely enough when I move the swinging arm up and down. It must be stuck in the frame?
rightsideup
Postby Puffs » Mon Jun 23, 2025 3:55 am
I suppose the reason for wanting to take it apart is that the rubber bushes 4 & 5 have perished? Or is there an issue with the engine mounts?
If the bushes 1 & 2 move freely when you move the swingarm up & down, then indeed, it's not stuck there - and that makes things even more difficult. Then indeed the spindle must be rusted onto the frame tube 10, and it gets even more difficult to reach with any penetrating oil. Still, that's the only thing I can suggest...
Postby rightsideup » Mon Jun 30, 2025 4:02 pm
Finally got the bastarding spindle out. I ended up using gallons of WD40, PlusGas, a hacksaw, extreme violence and ancient Celtic wisdom.
rightsideup
Postby Jay Bee » Mon Jun 30, 2025 5:50 pm
Attaboy ! Go for it !
Dare I say it doesn't look particularly rusty ?
No, I didn't think so ...........
Well, at least you are over the original problem.
Jay Bee
Users browsing this forum: Bing [Bot] and 21 guests
