Is there an oil seal on the gear lever shaft TS250/1?
Postby mhsilverw » Tue Mar 06, 2012 2:04 pm
On a TS 250/1 after changing the 'chocolate milk and frog spawn' that appeared to be inside the gearbox with some fresh oil.....I seem to have a slight oil leak from the gear lever shaft. :cry:
Is there an oil seal on the gear lever shaft for the clutch (outer) cover :?:
I cant see anything in the workshop manual or on here (know these are for the ETZ but assume similar (maybe!))....can anyone advise where or what I should look at the resolve!
http://www.youtube.com/watch?v=oIh2Zm2J4Ss&feature=BFa&list=PL2A765D4D23C0A45E&lf=rellist
Regards
Mark
mhsilverw
Re: Is there an oil seal on the gear lever shaft TS250/1?
Postby Old Dog » Wed Mar 07, 2012 5:50 am
There is from memory a rubber O ring but I have never had to change them, on an ETZ
hope this helps
All the best
Old Dog
Old Dog
Postby therealche » Mon Mar 19, 2012 8:08 pm
O-ring I think from memory 14mm x2mm? Kickstart one is 17mm x 2.5mm
therealche
