need pics of wiring!
Postby ghostinthemist » Sat Apr 07, 2012 4:16 pm
Looking for pictures of wiring form under the side panel to back light. No wiring diagrams have the brkae indicator on them and thats all i have left!
ghostinthemist
Re: need pics of wiring!
Postby ghostinthemist » Sat Apr 07, 2012 10:02 pm
for Mz ts 150 1974 american
ghostinthemist
Postby therealche » Sun Apr 08, 2012 7:13 am
Might be easier if you put up a picture of what you have got so we can scratch our heads! Does your bike use the brake switch in the rear brake plate? The standard wiring is a black wire running from the coil to the bulb, and another black wire running from the other side of the bulb to the brake light switch on the brake plate. If you are using an external brake switch, take the second black wire to that, and a wire off the other side of the switch to any earth pont.
therealche
