adjusting idle speed ts 125
Postby elsinore401 » Fri Aug 31, 2012 3:54 pm
Hello, I can't find any screw to adjust the idle speed on a 1977 ts 125 with the vbk carb. Thanks
elsinore401
Re: adjusting idle speed ts 125
Postby therealche » Sat Sep 01, 2012 8:44 am
Nope you won't! there isn't one. Heres a link to a how to guide for setting the tickover
http://www.mzrc-cornwall.org.uk/mod/res ... php?id=267
therealche
Postby DAVID THOMPSON » Sat Sep 01, 2012 12:58 pm
read the directions that's cheating
using the throttle cable to set the idle speed
lost an idle set screw once did that to get home
Postby elsinore401 » Sat Sep 01, 2012 2:18 pm
Thanks for the reply guys, it just seemed like if I used the cable to adjust the idle, there would be no free play. I will give it a shot later today. Once again thanks for the info.
elsinore401
Postby therealche » Sat Sep 01, 2012 3:33 pm
Not cheating Dave thats how MZ did it honest!
There's a mixture screw but they didn't bother with a idle screw.
therealche
Postby therealche » Sat Sep 01, 2012 3:41 pm
As opposed to the carb used on the TS250/1 which has both
therealche
Users browsing this forum: Blurredman and 23 guests
