backfire
backfire
Postby gary martin » Sat Apr 16, 2016 4:49 pm
the last time my 251 saxon tour ran, there was a large backfire, followed by poor running for a short time. another large backfire followed then it did not run again. i think there is no spark. could anyone point me in a likely direction to find the fault. many thanks.
Gary.
gary martin
Re: backfire
Postby DAVID THOMPSON » Sun Apr 17, 2016 9:49 am
backfire can be a sign of ignition problems
Like some one turns the key off and on causes backfire
a loose wire can cause it
Re: backfire
Postby gary martin » Sun Apr 17, 2016 11:53 am
DAVID THOMPSON wrote:backfire can be a sign of ignition problems
thank you for the reply, are there any weak areas of the ignition side?
Gary.
gary martin
