TS250 Battery
Now it is up and running I need a decent battery, if I leave it for too long it just goes flat.
I have checked that it is charging and it is, I have also checked that there is no leakage with the ignition switched off, the battery looks pretty old so I want to replace it.
If I use it every day no problem, but leave it for a week or more the voltage drops to about 3 volts.
I want to replace it with a sealed battery, but there does not seem to be any 6volt 12AH ones available.
This being the case I am thinking that I dont need a 12AH one anyway as I wont be riding in the dark so all the battery needs to support is ignition, indicators and stop lamp, so probably less AH will not matter.
Any thoughts / recommendations ?
Thanks.
Thanks.
