Fuel Tap TS 2 Stroke
![Post Post](./styles/prosilver/imageset/icon_post_target.gif)
Has any one successfully used a different fuel tap on their bikes? I have been having a running battle with several standard fuel taps trying to get them to seal around the plastic bowl and around the plastic outlet pipe fitting. All appear to have a very critical sweet spot when tightening and have tried small rubber "O" rings and PTFE tape on the threads with varying success. In both cases the issue appears to be the thread connection between the plastic element and the alloy body of the tap. So and advice will be greatly appreciated!
