TS250 Supa 5 1983. Carb questions.
Hi
I am trying to resolve a slow running/flat spot issue on my Supa 5. I have the carb apart to check the jet sizes fitted to it etc.
1. I notice that the carb is a BVF30N2-5. Other info I have says it should be either a BVF30N2-3 or alternatively an N2-4. I'd like to in down which one it should be, what the difference is and whether it is likely to matter.
2. The slow running (pilot jet) fitted to mine is a 45. The MZ manual and the Haynes manual state 35. Any advice on this would be appreciated.
3. What does the slide cutaway dimension mean, and how do I measure it. The Haynes manual states "50-5mm".
Any informed tips would be welcome. The bikes runs very well under load, but is very hesitatant and flat on partial throttle openings, spoiling what is otherwise a great bike.
Pete.
Pete.
