Is there an oil seal on the gear lever shaft TS250/1?
On a TS 250/1 after changing the 'chocolate milk and frog spawn' that appeared to be inside the gearbox with some fresh oil.....I seem to have a slight oil leak from the gear lever shaft.
Is there an oil seal on the gear lever shaft for the clutch (outer) cover
I cant see anything in the workshop manual or on here (know these are for the ETZ but assume similar (maybe!))....can anyone advise where or what I should look at the resolve!
http://www.youtube.com/watch?v=oIh2Zm2J4Ss&feature=BFa&list=PL2A765D4D23C0A45E&lf=rellist
Regards
Mark
Regards
Mark
