Etz 301 ignition question
I picked up an Etz301 (not a kanuni) recently for not a lot of money, that I want to use in my newly (reconditioned and powder coated) 301 frame. The trouble is that I am using an Etz251 with points as the parts donator but the 301 engine has the later model electronic ignition, not points. The wiring diagram I have shows the 4 charging circuit wires as per the normal 251 stator, but it also shows ignition circuit feeding into a "black box" before feeding to the ignition coil. The link below shows this at the bottom
http://www.ostmotorrad.de/schaltplaene/ ... an_12v.jpg
Does anyone know what the black box is and where can I get one from...? I think it is a Cdi unit of some kind
