ETZ250 Carb Adjustment
The ETZ is running rich (black spark plug) and runs poorly in lower engine revs - approx to half throttle where it then clears and picks up speed & runs as it should.
I've tried to adjust the carb with little luck - I can get it to tick over nicely (about 1200rpm) but anything less it becomes lumpy and won't idle.
Carb cleaned & checked and all appears well, timing & points gap is ok, new Champion plug fitted & air cleaner element clean too, all clips, rubbers etc are tight.
Is there a simple way perhaps to weaken the mixture via the pilot air screw without compramising tickover.
Presumably turning the screw out 'weakens' and in 'richens' the mixture.
Many thanks
Andy
Many thanks
Andy
