CANT GET 74 TS 250 STARTED
Posted:
Sat Apr 13, 2013 6:58 pm
by N1YDP
igot a 6 volt battery for it. it is one of those small ones like a moped takes.i have blue spark but i have to put my hand over it to see it.would it be because the battery is to small.?
Re: CANT GET 74 TS 250 STARTED
Posted:
Sat Apr 20, 2013 7:48 am
by davegsm82
Not likely, if you have a good spark, in the right place, and enough fuel then you should have ignition.
Is the plug wet (fuel) after a good few kicks of the starter?
Your plug-cap could be breaking down under load (engine compression) and leading to no starting.
Dave.
Posted:
Sun Oct 06, 2013 1:13 pm
by N1YDP
have good spark,compression about 135,battery at 6 volts with key on.i put some gas in the cyclinder and it still didnt fire.i am using my weed wacker mixes gas,that shoulnt be the problem should it?
Posted:
Sun Oct 06, 2013 3:36 pm
by N1YDP
found the problem.i think i need a bigger battery,i have a 6 volt 4a battery but i dont have the alternater hooked up.i am running it direct to the coil.if i hook my battery charger to in it runs great,but when i unhook the charger it runs for about
5 seconds and dies.if i get the alternater hooked up would that battery work.
Posted:
Sun Oct 06, 2013 4:04 pm
by N1YDP
yep! need bigger battery,need a 6n11a1b.4 amps wont cut it
Posted:
Sun Oct 06, 2013 9:44 pm
by DAVID THOMPSON
its not going to be cheap as they do not sell a lot of 6volt MC batteries any more
Posted:
Mon Oct 07, 2013 6:56 am
by N1YDP
$28.00 shipped with acid.love ebay.
